Use this procedure to specify the nickname allocation prefix and enable Dynamic Nickname Assignment.
You must disable Dynamic Nickname Assignment before you can change the nickname prefix.
Configure a nickname allocation prefix and enable Dynamic Nickname Assignment:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#spbm nick-name server prefix C.30.00 Switch:1(config)#spbm nick-name server
Dynamic Nickname Assignment configuration values and their associated behavior are shown in the following output from the show spbm command:
Switch:1>show spbm spbm : enable ethertype : 0x8100 nick-name server : enable nick-name allocation : static nick-name server range : C.30.00-C.3F.FF
The following table defines parameters for the spbm nick-name server command.
Variable |
Value |
prefix x.xx.xx |
Specifies the nickname server allocation prefix. x.xx.xx uses the form X.X0.00 from 0.00.00 to F.F0.00. A group, X.X0.00 to X.XF.FF, can provide up to 4,096 nicknames. The default nickname allocation range is A.00.00-A.0F.FF. |
